TwinTurbo.NET: Nissan 300ZX forum - Re: Timing Belt, Injectors, Clutch replacement and more
Subject Re: Timing Belt, Injectors, Clutch replacement and more
Posted by CmyZ on December 21, 2009 at 12:04 AM
  This message has been viewed 74 times.
In Reply To Timing Belt, Injectors, Clutch replacement and more posted by oherr on December 19, 2009 at 05:40 PM
Message I would pull the motor, that way you have easy access to everything.. if its an N/A its easier than a TT..
then you can also do the waterby pass and EGR delete.. valve covers, knock sensor, timing belt, clutch, rear main seal, oil pan.. etc...etc....
